Diesel JD
....Is the install? Lets assume I have all the yokes, driveshafts and linkages I need and access to a mechanic's shop, no lift but plenty of transmission jacks and such to safely support the transmission and give me room to work under. My mechanic friend would also help if I got into a jam but I'd want to use as little of his time as possible just cause I want to do as much as possible myself, to keep costs down, and because he's usually got plenty of other better paying gigs going on so I don't want to waste his time. Looks pretty straight forward and if I do this I will have something else to drive for a few days or more in case it goes weird but I don't want it to be down weeks or months. Is this something I could accomplish within a week or two if I worked on it every evening for a few hours or should it not be that big a deal? Also would everyone be comfortable having the brownie hanging from the cross member and a couple appropriately sized bolts/nuts/mounts or should I plan on a lot of additional support. If so...what? Thanks guys.
