Your working/sled pulling trucks don't relate to our motors due to the electronic controls. I am asking about IDI's.
:***: Where did I mention electronic engines in this thread?
Where are you guys getting all your basis for a daily driven, dependable engine when the article is clearly comparing engines built for other uses?
Even the Audi race diesel apparently has a powerband between 3000-5000 RPM
So it already has a wider, usable powerband, than an IDI. Plus it's an electronic, high tech diesel, which is not allowable in this discussion, as it's not an IDI. Arguably, you have 1300 rpm to work with on an IDI, unless you like to really abuse it by lugging it below 1400. Everyone says they start falling on their face around 2700, and while they will turn 3300 stock, don't do much at that point. Yes, they have peak hp at point, but the torque curve has fallen way off, and the horsepower is purely a function of the RPM. So why not setup the engine, fuel, timing, etc, to increase the powerband from around 1500 up to about 3500? Believe it or not, the stresses of making power at a slightly higher rpm are lessened over lugging the **** out of it.
In my quest to build a high performance(so to speak) IDI, I'm wanting to build something that will hold together at 4,000 rpm, but only pulls hard to about 36-3700. Usefully extending the powerband while not killing the engine.
And why on earth would someone compare a 2 stroke Detroit, with maybe a 2-400 RPM powerband? They are great engines, I love them, but there is absolutely no comparison.
I don't want high rpm, I want a BROADER powerband, and that's what is available with pushing them a little. Will it detract from reliability? If used right, not one bit. You guys have your minds made up, and I'm just throwing facts out to supplement your opinions on engine, and what can be done.
And the one thing everyone seems to forget, is that if the motor produces a broad, linear torque curve, even as RPM, drag and friction increases, the power will continue to rise, as HP is calculated off RPM and torque. Hence my DT466 example.
