mankypro
Learning Slowly...
I've been trying to figure out where to plumb a coolant line from and where to return it to for my fuel tank heat exchanger.
I've heard opposing views from folks on the following:
The 1/2" NPT on the top of the water pump being pressure or suction.
And where or not the 1/2" pipe plug on the heads towards the rear of the vehicle are cooling ports or not. Both my front head fittings are occupied - one with a temp sensor - which I guess I could put into a 1/2" NPT Y or T fitting then run my hose to the heat exchanger from there. But I'd rather not and have a dedicated pressure port and a suction port.
So right now the most important thing is to find out of the fitting at the top of the ater pump is suction or pressure.
Please? Anyone?
Please? Anyone?
