Flexplate to crank bolts
mctwisty
dayton, ohio
I'm not sure this is the correct place for this, but if you read my intro post, you'll see I got my truck with a bucket of bolts. My problem is, there were only eight flexplate bolts, and a dealer is wicked expensive, so, does anyone have a bolt that they're willing to part with- or, if you don't want to be stuck with a partial set, nine bolts you would be willing to part with? Again, sorry if I'm in the wrong place for askin'.
cpdenton
Truck needs paint.
Conway AR
Do you have the flexplate spacer? And I will assume since you say flexplate, this is for a flexplate for an e4od.
cpdenton
Truck needs paint.
Conway AR
I hope you have some luck finding one. I have a set, with the spacer, but just don't want to break up the matched set.
On another note, when you do go to install these, make sure you use thread sealant on them. Oil will leak through the threads as the crank is tapped through to the crankcase.
These is a forum here for buying and selling. Might post there?
http://www.oilburners.net/forums/forumdisplay.php?32-Marketplace
i have flex plate bolts out of an 88 auto somewhere, will they work?
clueless on automatics.
As already posted you need to seal the threads or a horrible oil leak past the threads will happen. Also note the torque is 47 lbs.
Here is a real simple question....how long are the ones you have...I have located my Crank bolts....thus...might be able to spare one.
I may have a bunch of new ones. Ford NOS. 1.75 long you say, I can check.
If you guys hqve complete sets qnd ONLY one set...and mqybe I hqve four sets...I will toss couple bolts in bag send to brian with his care package he can send off them if he likes....will check in while my sizing....
consider it done
McTwisty, pm me your address.
we should make this guy donate 10 bucks to the site... LOL
http://www.oilburners.net/forums/payments.php
