ironhorse2021
ironhorse2021
Hi all,
First post and thanks in advance for any input.
The PO used epoxy to seal the small oring leak path in my fuel heating element. Now it leaks and I can't separate the metal plate from the plastic frame that holds it. I posted in the Market section looking for a good heating element (metal and plastic parts) because I'd like to keep that function if possible. If I need to eliminate the heater and plug the hole in the manifold plate, would appreciate hearing how someone else did it.
Thanks
Thanks
