Nice extra find on the block but... The only true way to know if the block has the turbo rods is to open it up. At least remove the oil pan.. If this engine has an oil pan gasket be sure to remove it. Otherwise you will be seeing leaks. The rubber or cork pan gaskets never seal well and they are an aftermarket only idea. Someone wants to sell you something you don't need in a gasket kit. Pulling the pan is how you can see the rod part numbers. We can tell you what they should be. Also what is the serial number on the block. The stamped number up by the injection pump gear cover should be above 1,116,331. All the 7.3 non turbo blocks were below that number and they started at 500,079 and went up to 1,116,330... Hope this helps out those looking for numbers. Actually the casting numbers on the blocks have either a C1 for non turbo or C3 for a turbo block cast into them.... Now you guys know it all about the blocks.... Knowledge is power when your buying or looking for something...
