bigoilburner20
ok gen still trying to figure out the whole settings
Installation is easy. The FASS/Airdog systems are solid reliable too. I prefer the cleaner look and the ability to drain or change filters without opening the hood. They are set at 16psi from the manufacturer, but you can order a pressure spring to lower them to 8psi for the IDI IP.
I mount them to the drivers side of the frame (outside), just in front of the box. I also build a rock guard shield for the front to make sure filters don't get poked by a rock. The FASS system is 90gph or 150gph. I don't see any need for the larger system.
I sure do notice a huge lack of performance when my system is getting clogged. Volume delivery just disappears when trying to climb hills or staying at a steady 70mph.
When accelerating from a dead stop I can watch the psi gauge just go to 0 truck will still run.
I do lose a huge amount of torque.
Once the filters are all flowing and psi is steady the power just hangs on instead of falling on its face on a gear change.
I have bypass regulator and completely revamped fuel system that works but I am in the process of upgrading both primary and secondary filters, want to use larger style filters for more capacity and longer intervals and mostly for better free flow during use.
My Primary is a Fram HPG1 and in the last 2000 miles I have changed that filter 4 times due to a dirty batch of fuel.
Time to getter a much larger primary filter.
Javier
Aye, that's how it works. Or, should work, as I've never seen mine come on - I know the light and wiring are good, dunno about sensor, but I'm sure I'll find out when she starts bogging down soon after a refuel w/o the light coming on.If your filter is clogged , then your injection pump is in the position of being in a vacuum as mentioned, Thats not a delivery issue, thats a restriction issue. If Im not horrible mistaken, thats what the sensor in the top of the filter head senses for is a vacuum in the line between the head and the injection pump . and triggers the filter light.
What was the issue, junk fuel or just summer blend that gelled on you in the cold? If it was the latter, couldn't you have just added some "Diesel 911" or equivalent and wait till it's done doing its thing, w/o pumping out the tank?When you get a junk batch theres not much more you can do aside from pump off the tank ( I made teh fatal mistake of filling my large tank before heading north in the winter once... yeah, really dumb, but it had been a long time since I'd been up north . My switchover valve was jammed and I ended up pulling into a truckstop in Illinois and having the bed tank pumped off *OUCH* but it had to be done or I would have been out in the cold changing filters every 40 miles till 130 gallons got burned up . It would have cost me more in filters and a possible tow, than it did to loose the fuel. Instead I got off changing 2 more filters and ran the rest of teh trip. ( and I was pulling a 32 footer )
Aye, things like taking a propane torch to the filters and steel fuel lines, and lighting small camp fire under the tanks?( I'm used to running big trucks in the arctic, so I know tricks for getting fuel to flow that would make most folks cringe... and I tried them all )
But it seems to me that your mistake wasn't filling up the big tank w/ southern fuel before heading north, but rather filling up the whole thing from one place that just so happened to sell crap fuel - which is not really a mistake either, it can happen to anyone anywhere - well maybe the water will freeze in the storage tanks in the north, but algae would still get pumped right in your vehicle just the same... Tis why I think it silly when some folks remove the two factory tanks just for the heck of it and replace them w/ one big tank - true the system has the same capacity and less parts to fail, but now if something happens there's no fuel reserve to switch to and keep on going.
