jonathan
did the hydoboost brakes make a big differance?
I would have left the SRW front wheels on there, I just wouldn't be comfortable with that much stud left
http://farm6.static.flickr.com/5018/5560233816_1bf2632f5a.jpg[/img][/url][/URL]
You must be registered for see images attach"]You must be registered for see images attach[/URL]
Yeah your not kidding on the adapters. But they are 100% american made steel and machined in the US. To me, that is worth the money. I asked my local tire shop what lugnuts to use and they said that it would be just fine using heavy duty acorn lug nuts. They centered the wheel good and they torque well. I would have used a shanked nut, but with the studs being 5/8 in. That was not an option. I have the same nuts on the rear adapters i got from you.
Is the wheel tapered to accept the acorn style lug nut or was it just a round hole?
The rear adapters you got from me had steel wheels on them and the rim has a taper to accept acorn lug nuts
Well to be honest, i'm not sure about that. Now you've got me thinknig though. I dont think they were tapered, but i do remember checking to see that the taper of the lugnut fit in the hole of the wheel.
If the wheel is not tapered for the acorn lug nut then you can NOT use them.
You need the washered style lug nut
