ok wes, thanks. Ever hear of ProDiesels from Alabama?IP shouldn’t make any noises. Take the top cover off and see if you see any corrosion or coloration in the pump, you can post a pic if you like. You may have a thrust bearing failure immenent, maybe take the accessory belts off and see if the noise remains.
I have and they have an "f" rating by the BBB.
https://www.bbb.org/us/al/cottondal...diesels-0463-90172727/overview-of-bbb-ratings
Assuming it's the same place that you're thinking of.
