F350 crew cab 6.9 idi
jose.castillo.921025
Abilene, Texas
I want to get better fuel economy out of this truck what auto transmission could I use on it?
I'd like to make it manual but don't know what other parts I would need or which tranny would bolt up to it.
Help please
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Waystro
No Class
South Texas
Put your truck in your Sig so we know what Trans engine etc you have. I'm assuming you have a C6 Automatic.
if you want to keep it an automatic then the E4OD is your best bet but you need a computer to run it.
if you want a manual than the ZF5 is the best option.
any diesel ZF5 ford used from 90-97
a set of pedals
master & slave combo
flywheel and clutch.
maybe driveshafts...
Diesel zf started in 88. Maybe some rare 87's.
I would go all out and run a standalone trans computer.
C_Luft
Vancouver, WA
Or you could add a gear vendors over drive and only really need to shorten your drive shaft, that way you have a bullet proof drive train, with no electronic crap to go wrong.
FarmerFrank
Blairsville, Pa
Is your truck 2wd or 4wd? I have a 2wd overdrive box that will bolt directly on a c6 but you will have to shorten the driveshaft
Black dawg
sw mt
Is this truck 3.5 geared or 4.11? If 3.5 ratio, the mpg improvement may be very small.
Alleycat
