F-650 with optional CUMMINS
Max Power
That thing is sweeeeeeeet. Wow, I'd love one of them. Too bad probably no 4x4 :(
Whit
lost in Why-homing
Both the Ferd and the IH are a 4x4, I cant figger how to get that rig under my 5er though :mad:
Cheers, Kevin
cat320
Too far out of reach for most need that $100K to just look I bet .Then just seams to be a waste of truck to use it for just tooling around.
Duke
PA
NBA star toy. The IH is prolly a better truck, although they're both rolling off the same assembly line now that IH is building Ford medium chassis.
I'll take the DT over the 5.9L anyday.
Gooch
SOUTHERN ,NH
Actually, I know this person and good level that builds the F650's and he seems to be able to do what you want .. I want a f650 but for 89,000 base price i could buy a mobile home or something. I want on badly that be a kewl but expensive daily driver!!!!!!!!!!!!!!!!
Sbrem
Guilford VT
Definently. No quesiton about it. The 5.9 is a great pickup engine, but in a medium duty probably not the best choice.
Stephen
Duke
PA
Hey Stephen,
Isn't it funny how if you drive M/D's consistently with DT's, Cummins', etc., you can truly say that with confidence?
2500cummins
Not far enough from Vegas
Comparing the B5.9 cummins to the DT466 is an apples and oranges thing, the C8.3 Cummins is a lot closer comparison, the DT probably still wins anyway;)
The last time I looked at the ford website it still showed the 7.3 in the 450, 550, and as the base engine in the 650? The 6.0 was only shown in the 250 and 350, is this acurate or is the website out of date?
Duke
PA
Whitmore,
The DT466 is probably one of the best M/D diesels ever. It started as a mechanical, rotary pump diesel back in the mid 70's. It then changed over to an in-line Bosch pump up until ~'95, then it became the DT466E (electronic).
Most popular power level is 210/540. It makes ~90% of it's torque on clutch engagement, so it doesn't bog down out of the hole.
It's found in trucks from 22,000-76,000 GVWR and many types of farm & commercial macinery, even log skidders, so it's quite versatile
It has many power ratings up to from 190/520 up to 300/860 and has very few known problem areas.
It is very cheap for parts. I have a friend working at IH parts and has quoted me $5,500 for a completely new engine....much less than most light diesel engines.
ntjapkes
