Extended cab side window trim
Oldiron
Florissant, CO
I can't find how to remove the side window from my '88 f250. Do I simply pry it off? Just below my drivers side is starting to get some small surface rust and I want to remove the trim clean it up and prim it.
riphip
Memphis, TN.
Pull interior trim out & should have nuts on the outer trim mounting posts. Be very careful not to break these
chillman88
Central NY
So the outer trim piece is attached from the inside??? I NEVER would have guessed that. Are the mounting posts going to be brittle plastic studs?
(Sorry to threadjack, I had the same question haha)
riphip
Memphis, TN.
As I recall, yes they are plastic on my '86. '88 may have metal inserts. Once you pull the interior panel it's easy to see
aggiediesel01
Houston, TX
Our '91 had metal studs. The studs penetrate the holder that holds the glass and the glass holder is stuck to the body with a thick butyl rubber strip around the edge. It's likely that you can massage the metal trim out from the glass holder without braking the seal but be prepared to have to reseal the glass to the body of the truck if it comes unstuck while you're pushing on it. And wear two layers of rubber gloves, that butyl rubber is supper nasty gummy stringy stuff that gets everywhere and ruins any cloth it touches. Especially when it's warm. When I took ours out, I put each in a trash bag and put them in the freezer to solidify the butyl in a way that made it peel away from the glass holder without smearing and creating a hell of a mess. It took two trips to the freezer each to get it all off for me.
catbird7
PA
Definitely bolted in and requires removing interior trim to access fasteners. Take extra care handling that plastic cause it's old, brittle, and sometimes difficult to locate replacements. Biggest problem will be getting the should belt anchor bolts out.
