Explain this upgrade to me please.....
Captain Morgan
Pipeline Mechanic
Sidney,MT- Franklin,TN
The following is an exerpt from and ebay listing.......
Description
PERFORMANCE MODULE FOR INTERNATIONAL/ NAVISTAR T-444E DIESEL ENGINE
THIS IS A BRAND NEW PERFORMANCE MODULE FOR THE INTERNATIONAL HARVESTER MEDIUM DUTY TRUCKS WITH THE NAVISTAR T-444E DIESEL ENGINE. THIS MODULE WILL INCREASE THE POWER OF THESE ENGINES BY 60 HORSEPOWER AND 100 FOOT-POUNDS OF TORQUE. THIS MODULE PLUGS INTO THE ICP SENSOR LOCATED ON THE DRIVER-SIDE CYLINDER HEAD AND MOUNTS UNDER THE HOOD. INSTALLATION TAKES 10 MINUTES OR LESS. THIS MODULE WILL NOT RAISE EXHAUST TEMPERATURES BEYOND SAFE LIMITS, NOR WILL IT CAUSE THE ENGINE COOLANT TEMPERATURE TO RISE. IN FACT, YOU MAY EVEN NOTICE A DECREASE IN ENGINE COOLANT TEMPERATURE DUE TO THE FACT THAT THE ENGINE WILL NOT HAVE TO LUG AS HARD AS BEFORE. THIS MODULE WILL GIVE THE T-444E ENGINE MORE LOW END TORQUE, WHICH IS SOMETHING THESE ENGINES DESPERATELY NEED, AND WILL ALLOW YOU TO CLIMB HILLS IN A HIGHER GEAR. THIS MODULE WILL ALSO ALLOW YOUR TURBOCHARGER TO SPOOL UP FASTER WHILE ACCELERATING. THIS MODULE COMES WITH A 2 YEAR WARRANTY. I ALSO HAVE OTHER MEDIUM DUTY TRUCK MODULES AVAILABLE FOR THE NAVISTAR DT-466E, CUMMINS B AND C-SERIES, AND CATERPILLAR 3126B, E, C7, AND C9 DIESEL ENGINES. PLEASE E-MAIL WITH ANY QUESTIONS.
This sounds just like snake oil to me, tell me Im wrong.cookoo
Mark Craig
Advertising Sponsor
Franklin, TN
Captain Morgan,
We have sold a lot of the TS MP8's on this appliaction, Cats, Cummins and other. They work great and are a lot more than a 10 mod or resistor trick. They do boost fooling and are adjustable. It's a programmed module etc. if you have any questions on it call us.
Mark @ DPPI
REM70
