engine swap into a WHAT!!!
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Has anyone out there ever put a 300 I6 gasser in a jeep.Thought about getting a 1974 postal jeep(DJ5) with blowed up AMC engine(they are asking $500 with VG body).Found a 84 300 with 3Spd tranny out of a truck for $200.I know the 300 is 8" longer than the 242AMC.Has anyone ever attempted to do this?Looking for a cheap replacement for the Falcon(F250) and don't want a cookie cutter car.I want something more....Me!Something I can tinker with on the weekends that gets decent fuel mileage(said decent not great!),Don't mind getting the interior dirty(Work in a machine shop cutting cast iron....Lots of dust,grease,oil,unknown slime!),and won't feel bad if I cut a hole or two for special additions(Muh Ha ha ha ha).
Lastly,Anyone know what was hooked to the back of a 300 in 84 with 3 gears?Mechanical,Hydrolic,internal,external actuated clutch fork(which one?)?
Freight_Train
Gadsden,Al
adrianspeeder said:
The three speed auto tranny is the C6. I didn't think they had three on the tree manuals in 84.
Adrianspeeder
I need to call them then.You can't kill that setup!I tried!boiled ever bit of water out of the 300 after it threw a fan belt and it still ran great after I refilled and rebelted i.Sold to cousin that never checked the fluids,ran it I think 2 or 3 quarts low of trans fluid(pan leak).Refill and trans shifted perfect.Not to mention he was hell on that tranny and engine.Drove it like a honda.Power braking(well attemted to),kicking it sideways to spin the tires,blaa blaa blaa.That truck was indestructable other than the 8.8 took a dirt bath(PO got up in it before I bought and did something.Spider pin lock bolt was broke off and JB welded,Spiders were razor sharp,pinion would move in and out a 1/4" if you turned the drive shaft by hand not to mention CLUNK real loud going from reverse to drive or visaversa).
jlayne
Bondo Bandito
Milledgeville, GA
i have a 81 F150 that still used the 3spd man. but i think it was phased out... definately sometime before 86.. not sure if it was before 84
if i was interested in swaping a 6 for another 6 in a jeep i would say find a 4.0 out of a newer jeep and toss it in.. they are cheap, easy to find, and very good mills
it would be almost a bolt in replacement for the 242 also... if you wanted to spend the dough you can even get a "stand alone" fuel injection kit for them and run fuel injection which would be very reliable and get excellent fuel economy
You can put them in a Jeep.
You can also get a 4 barrel intake manifold with a small 390 cfm holley carberator and get 300 hp out of them. All available from jegs.
Anywho I think advanced adapters has an adapter that will probably work on the original tranny.
Good luck,
Paul
BJS
SW Hellanta GA
don't know what you consider excellent fuel economy. brother w/ 4.0 in his jeep is only pulling down mid to upper teens.
The tranny if auto is more than likely not a C6 since the small block C6 trannies were generally put behind the larger power motors (351) It's quite possibly a C5 which is still a pretty good tranny just not quite as strong as the C6.
in '84 they also offered a 3 speed manual tranny I believe that it was a floor shifted tranny but I'm positive.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I've never seen one in person, so this is going strictly out of my '84 factory shop manual...but the 3 speed manual was available in '84 and was a column-shift. There was a "3 speed with overdrive" available as a floor shift, but it sounds like the tranny had 4 gears overall (probably the 3 speed column-shift with an overdrive gear added, but that's just an SEWAG).
Just FYI :)
WILLD
The o.d. trans was a beefed car type. Not much for towing, but it saved on the gas.
REM70
