FWIW I went to the corner hardware store and found a grey made by Rustoleum. Been on for five years now and still looks great. Probably can't go wrong with any name brand. The key is good prep work. Clean, sand and clean before you coat and life should be good.
Good luck,
Doug
'86 F-250 4x4
'89 E-250 ATS
VHT stuff is good. It withstands about everything. Only thing that seems to have damaged it so far is fuel or coolant that sits on the engine while it's running. That seems to make it want to flake off.
However, i used the flameproof vht stuff on the exhaust. Painted it black. It started off rusty looking. I used a wire brush and cleaned it real good then painted it, then baked it. Looks perfect still.
