trapper
Boom Boom
Well a few days ago my Alternator overcharged and went kaboom i could tell after almost all the fuses in my fuse box popped at once after replacing the fuses i would turn on the lights and for some reason every time i pull out the light switch it pops fuse number 4 and sometimes the fuse to the dome lights, i put in a bigger fuse to see what it would do but when i turned on the lights the wires would get so hot they would start smoking, Ive also tried 2 different light switches the lights would be dim and the wires would get hot as stated so i stopped with it, my rear break lights wont work either but the drivers side will flash when the hazard lights are on and they are very bright im stumped as to what is going on and this didn't start happening till the alt F%$ked up any help is needed and appreciated
