Electric fuel pump
Clb
Another old truck
nannyfornia
Your attatchment failed.
Op
There is a new issue mel found with retarding timming due to inlet psi.
Not huge but...
Clb
Another old truck
nannyfornia
Aka mel
Did some math.
I read it here.
Brb.
Clb
Another old truck
nannyfornia
My ifail is giving me grief...
Mel posted an in depth test he ran on a db2 with increasing psi input.
The facett pulls about one deg. of adv. out of the pump.
At some point it killed the advance altogether.
So retime your ip after the lift pump is in.
Fwiw
I run a facett.
FORDF250HDXLT
Maine & Oklahoma
attachment.php
that's an interesting way to make a normal battery terminal into a marine style.i would think the ears will break off after a while.you could try keeping them stronger by putting the top on too but if i were you,i would just buy some marine terminals and avoid a future breakdown.
JLtoolman
Garner, NC
You guys are ignoring the fact that a pump listed at 9-11 pounds static (no fuel flow) only puts out 5-6 psi with the engine running (at idle). This is due to the bypass of the filter, use by the engine, bypass of the injection pump, and the bypass of the injectors.
Clb
Another old truck
nannyfornia
I believe that may very well be true, I see value in mels test.
FORDF250HDXLT
Maine & Oklahoma
FWIW: The Facet website lists the operating pressure of pump number 40237 at 9-11 PSI.
There are a couple that run right at 4-7 PSI listed as well
Why not just install a pump that operates at the right pressure?
http://www.facet-purolator.com/dura-lift-pumps.php
yeah,that's what i say.when most of us are running the 4-7 psi version issue free (even with moose ip's) why not go with whats proven to work.:dunno
but one could argue with this 2 fold;
there are many running the 4-7 psi version without worry or issues and secondly,the oem lift pump only provides the same amount too,so if this wasn't enough to feed the ip,the fuel light would be on all the time and oem lift pump wouldn't be enough either.that said,you probably wont and shouldn't experience any issues with either pump.
Clb
Another old truck
nannyfornia
Ok I am gunna bump this thread till I find the one dealing with the dash light coming on at full throttle...
My group buy pump,ats 093,stock rig is firing the fuel light on full pull situations.
No crap in the lines.
Gunna put a pressure gauge on the filter head.
I saw a post about a restrictor in the returns to up the feed inlet psi., any one else see this issue?
crash-harris
Breaker! Breaker!
Chillicothe, OH
You mean the WIF light? Mine hasn't tripped any lights, but pretty much drops to 0 psi if I put the skinny pedal on the floor. Using a 40222 pump.
Bradz
