Electric fuel pump on obs
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
I used a stock 6.0 HFCM in my OBS.
So that's what that thing looks like!!!! LOL
On a 4x4 6.0 it so tucked in behind everything it's hard to see and get to..... I've learned the tricks, but out in the open like that would have been nice. On my Excursion with having the rear mounted 44 gallon tank, vs the side tank on a pickup, there is several feet of open frame rail not far behind where it's mounted..... but no, is beside the transfer case, above the crossmember...... LOL
Just for reference for anyone coming across this thread and wondering about the filters, and the post filter comment...
The 6.0 HFCM (Horizontal Fuel Conditioning Module) is the the primary filter, water separator, Water In Fuel sensor, Fuel Heater (Not used in later 6.0 and eliminated from the HFCM on later production vehicles and the replacements) fuel lift pump (capable of 60+ PSI, regulated at the secondary filter, pressure regulator assembly on the engine) and the fuel return location.
The 6.0 uses the Motorcraft FL-2016 replacement filter kit, which has both filters and replacement o-rings for the caps (the 6.0 uses cartridge style filters, so there is a permanent housing and removeable cap).
The primary filter is a 10 micron filter, and has the water block membrane to facilitate water separation.
The secondary filter, mounted on the engine near the oil filter is a 4 micron filter.
Some reason I thought that the primary was larger micron. (Never bothered to look)
That's already on part with the 7.3 filter, iirc.
u2slow
bilge rat
Coastal BC
My buddy plumbed dual stock SD pumps on his '99 PSD (on switches; one running at a time.)That was his way of covering for a pump dying on him.
FarmerFrank
Blairsville, Pa
I went a little over board on mine for fuel lines.
Mine goes from selector valve to the fuel pump then #6 (3/8) hydraulic hose to the filter head. Filter head to custom steal lines with another hydraulic hose. It works and I don't have hose clamps go leak. I did have to make custom fittings to go from the metric threaded pump to a #6 hose but brazing fittings together doesn't bother me.
Lines in the valley
Only pic I have of the engine to help show the filter plumbing.
FarmerFrank
Blairsville, Pa
Oh and the valley lines are 5/16 brake line. I wanted to get away from any olive fittings. As you can see it was much easier to mock up on a stand. I probably wouldn't have went that route if it was in the truck. It was a ****** getting those to clear the turbo just right.
