Electric Fuel on OBS
aaklingler
Winfield, PA
Where can I find some detailed info on installing an electric fuel pump on an obs truck, detailed parts list instructions and pics?
94f450sd
somewhere,ma
Go to superdutydiesel.com and search for it.
Pretty much all you need is a good adjustable regulator,99-03 fuel pump and whatever filter setup you want to run
Double-S-Diesel
parts seller
derry pa
ju did another one, used a SD pump on the frame rail, a SD filter and hpop res, swappe dto SD style hpop lines, use the SD feedto bowl, return from bowl and drain tubes.
custom bent my own head feed tubes using 1/4" stainless tube and vibra lock fittings, fed the rear of the heads, then returned from the front of the heads to a regulator, then returned from the regulator and tied into the stock return
720Diesel
