educate Me on this fuel pump
Exekiel69
Is this the same style pump as the holley red? I mean the guts inside are like the HR or more like the facet pumps (i think they are piston) style?
After some testing I start to believe the Holley pumps are stronger than the others I have used. This last if they pump dry for some time or if they have to pump on a restricted line they wear very fast and sooner than later start pumping very low volume. Now they holley has proved to be better in this same situation.
Thank You.
sle2115
NRA LIFE MEMBER
Southeast Ohio
It's a gerotor rather than a vane style pump. It also doesn't mention compatible with diesel.
REM70
