ECM locations
BigRigTech
Diesel junky
Nova Scotia, Canada
I'm gutting a 97 E350 and 96 F350. The ECM that is under the dash in the van and inside the drivers kick panel in the truck, what's it for? Engine, tranny? The one in the truck looks like a real PITA to get out, any tricks or tips? I need to take these out before I haul these things to my buddy's junkyard and the vultures set in.:backoff The bolts are spinning on the ECM in the van.:mad:
JLDickmon
Bo Duke
49041. OU812?
whizzer the heads off and fuggetaboudit
yeah, those are the ECM's. You might wanna grab the GEM modules, too, if they are equipped (not sure either are)
Mike
Stroker
Cora
In the 96 it will be easier to get the PCM out if you remove the inner fender well, but it sounds like this is a junkyard truck so just take two or three of the inner fender bolts out and pry it down out of the way so the PCM has room to slide forward out of the slot.
BigRigTech
Diesel junky
Nova Scotia, Canada
The one I'm talking about is inside the drivers side kick panel - buried behind the aluminum dash support structure...I can't see how it would slide forward out of the hole. It has studs that go through the firewall into the engine bay so you can put nuts on them.:dunno
Mike
Stroker
Cora
Thats the one. It comes out through the engine bay.
Heres a few shots of mine.
First shows the harness connected to the back of the PCM.
Second is the harness unbolted off the back of the PCM
Third is the slot that the PCM slides out of.
Fourth is the PCM out.
Fifth you see the guts of the PCM.
These shots were taken in preparation for my chip install, in that fourth pic you can see a chip laying in the background.
Heres where you want to unbolt/unscrew to pry the inner fender down.
BigRigTech
Diesel junky
Nova Scotia, Canada
I'll give it another shot...LOL...I sold a bunch of gear on the 96 F350 so I need to get this out before I take it to the boneyard to be stripped.
