where in maryland did you get this?
Bel Air. Bout an hour and a half to get there. Not too bad.
Yeah I use to live there a few years ago. Now I wanna see pictures of the truck see if I know it or not.[/QUOTE
Here's the craigslist ad... The link still worked when I checked. http://baltimore.craigslist.org/cto/4033068075.html
He kept the hitch (I got the receiver), I let him keep the CB antennas. Soon it will have the smoked tail / signals replaced with stock, new A/T tires instead of Mudders, maybe a new grill, a new hitch.
Oh boy, I'm not so sure anymore... The more I dig, the more I find broken and/or Jerry rigged.... My fault really. Not an experienced car buyer. I checked out what I knew to look for, but missed a lot. 4x4 doesn't engage, A/C and heat only blows out defrost so I got a vac leak. rear cab light was leaking so I ripped out the carpet and liner to dry/clean everything out after silicone sealing the light, has a bad U joint, bad tie rod end, and the engine compartment is covered in oil and I am having a hell of a time figuring out where it came from, etc, etc, etc,.... Ugh, just trying to get the GD thing inspected and in shape so I can start using it!that is not so bad, and I dont know that truck or the guy who owned it before. Not a bad buy at all.
High pressure oil lines?
I thought it was an IDI??
I didn't get to see the ad.....
Tbird was talking about the high pressure oil feed lines to the injectors on a Powerstroke.
I can tell by the part of it shutting down before damage happens, when too low on oil.
You won't have those....
It's most likely a combo of that rdt and leaky valve cover gaskets.
Actually the oil could be old. The intake hat for the turbo will leak and spray a oil mist everywhere. (When it's still hooked up)
I would put the CDR back to a factory setup.
Is the crud centralized anywhere?
Power steering fluid can leak onto the belt and get thrown around.
I am confused also, I think it may be an idit, witch in that case, everything I said was and is wrong.
