bike-maker
Pretty sure I'm going to end up buying a 84 F250 with 6.9/4 speed. Truck is rough but runs good; I'll probably part it out and use the engine for my truck.
I'm curious at what point the 6.9's switched from having the pressed in piston squirters, and which blocks were prone to cracking around the block heater.
I remember the 83 engines as the ones that had lower compression, but I could be wrong there.
Dug through all the FAQ's and tech articles, but didn't find the info I was after.
I wanted to stud my current engine and upgrade the cam, but it's making more sense to just start with a second engine.
Just not sure if the 84 is a good candidate...
