1994 Turbo
So i've been having some serious issues with the cooler lines. Tried using rubber line to fix where the steel leaks, nada. Double clamped 5/16 transmission cooler line onto the stock steel and it just leaks. What's everyone else do? I can't be the only one having this issue. Also, What about the dipstick nut on the 7.3 PSD? Mine has been leaking some serious oil and i just got around to crawling under it this morning to see the nut is completely gone and the piece is about ready to fall into the pan. I don't have time to pull the pan right now, so is there any way to fix that?
