cowman79
So i decided to drive my truck to work today and about 10 miles into my drive the torque converter unlocked for about 5 seconds and then about two miles down the road it unlocked again for a couple of miles. Then the OD light quit flashing and the truck stayed in limp mode. I pulled the codes when I got home to day and I had a code 23 TPS out of range A code 1 which I thought was weird and lastly a code 29 VSS. I just installed a new ford speed sensor about a month and a half ago. Also when the truck started acting up today the speedometer never bobbled not once. This is what I don't understand because even though it is throwing a VSS code why isn't the speedometer bouncing. Any help would be greatly appreciated. I installed my spare transmission computer and I will try that for a while and see what happens.
edit
Also this transmission has only been installed for about a week and only has about 150 miles on it. I have also had this code with the previous transmission. That is why I installed a new OEM sensor.
edit
