chumwon
Since I first got my 92 dually running the one thing to some what brag about was the good soild shifts all the way through the gears. I noticed slowly with more weight and power it wouldn't be nearly as soild of shifts, which is to be expected I suppose. But within the last few days my 2-3 upshift is weak an drawn out for a second...there are times it isn't quite as bad and I can notice the TC locking just after it. But when it's weak an drawn out you don't notice the TC...the 4-3 downshift seems fine...
I'm not a transmission pro at all but this doesn't seem good to me and I fear the worst of needing a rebuild... I've checked most the basics as in fliud was changed a while back with new filter, tps is within spec, fliud level and smell are decent, no codes, connections and grounds look good but haven't been cleaned out or greased yet..
I'm stumped and bummed while still trying to baby her around. I hope someone might be able to tell me about a solenoid pack or something minor in the valve body I may be able to do myself. Any input or advice is greatly appreciated! Thanks
