e4od trans dipstick help.
nhwrench01
new hampshire
so, after installing a stock turbo setup from wes, with a kit from russ. ( great guys, just want to give them more praise...) I need a new trans dip stick and tube,, I found the tube. but cant find a dipstick.
I do have the old dipstick from the n/a. from what I found the turbo dipstick length is 44.5"
from the tip (bottom) to the top part that hits the tube when fully seated in.
I can cut my old stick and make the "cold" and "hot" marks with the hatch marks on it. but what I need to know is,#1 can get a correct one, ill buy it,
#2 do I have the correct length (44.5)?
I have a huge deep pan and big stacked plate cooler I need to install soon, so I need to check the fluid after all this work. thank you for the help.. dave
Alleycat
