E4OD Suckage
torinoracer29
wonder lake, IL
Well headed out at 3:00 am this morning headed to pennsylvania for a couple weeks of work and made it about 150 miles from home when my trans **** the bed. This was a Ford Factory rebuild I put in 50000 miles ago that crapped out. So now my truck is in south bend, in. getting the trans rebuilt while I am in pa. working. Just really pissed at Ford and had to vent somewhere.:puke:
Ford generally has a good warranty but I don't recall the miles it was nor the years of service. Hope it works out in your favor too. Its tuff working out of town and being broke down sucks too...
benton
Country boy
Bushkill Pa
e4ods suck and seem like they always take a **** at the worst times i had 2 **** the bed with in a month of each other. what part of pa are you in?
Fozz
Camarillo, CA
I would talk to Ford, I thought they had extended the warranty on the trannies in recent years (depending on when you installed it).
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
Sucks man. All a guy can do is try to support the trans with maybe the TC lockup mod, a shift kit, and some aftermarket coolers and then keep your fingers crossed. I'm sure there is a lot more a guy can do, but it probably involves a lot of money...
dsltech83
Ellery,IL
Currently the Ford reman trans warranty is 3yr\100K. been that way for 3-4 years I think......
FORDF250HDXLT
Maine & Oklahoma
well thats not good.what were your symptoms?
trans temp was ok? did you replace the converter last time too?
was the od light flashing during any time you were driving it?
torinoracer29
wonder lake, IL
The torque converter was new, the od light was not flashing, the temp climbed up to 250 degrees within ten miles and then puked trans fluid out the vent on top and out the front. It is at valley transmission in south bend, IN. He is putting in the billet torque converter, shift kit and better clutches. Does that sound like a good rebuild. take out, rebuild, install and 1 year warranty for $2000.00. The guy was pretty cool he picked up my trailer stored it inside for me had my truck flatbedded and was the only one in the area that could get it done in a couple days.
It seems Ford has the same problem as Chrysler; A good strong truck engine but no auto overdrive tranny that will last behind it. I never have heard or know what GM put behind their 6.5's. Did they have the same problem also? Did they use the 700r4 behind their diesels?
FORDF250HDXLT
Maine & Oklahoma
whenever you see temps spike like that,you want to stop doing what your doing.preferably drive with no load,but pulling over and putting her in park for a few mins will do the trick.
if temps still climb,then shut it right down.unhook a trans cooler line and start the truck.see if she's pumping fluid still.if not then your plugged up somewhere or your pump failed.
had you shut her right down,you could have towed her home,fixed the front pump for around 100$ bucks and been back in action.
it's just like any other gauge.if your oil pressure drops what do you do? shut her off asap and let her roll to the side of the road.
if your EGT gauge reads high,you back off the skinny or drop a gear.
if you listen to your gauges asap,you can save loads of $.;Sweet
jhnlennon
WI
Yup, and the 4l80e, both of which are no exception to trouble.
Bigal093
