7.3 powerstrok
moved to psd
psd
psd
,,the reverse was grabby to the point it stalled the engine.
wat is the best way to determin if i should reuse the tc on the next trans ??
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachjust to clearify the transmission was a ford rebuild with 80,000 miles ,worked perfect ,disassembled it to install a 4x 4 out putt shaft ,with new gaskets ect ..the one thing i noticed when i had it apart was a melted plastic thrust ,i did not have the new thrust for this steel planetary so i used the aluminum one with the steel thrust /see photo also replaced the hub with a perfect one..
