E4OD shifting issues
ford5.9
ford5.9
waco/texas/us
I have a 93 F350 4X4 with the 7.3 diesel and I'm having shifting problems. If I start out with the shifter in the Drive position, it will take off in first gear and will rev to near 3 grand before it will shift into second. Once it goes into second I'm at a high enough speed that it goes right into 3rd and then into OD. Almost seems that it skips 3rd it goes into OD so quick. Now, I can start out with the shifter in 1st and manually shift into second and everything works fine. Then I can shift into Drive and as long as I'm below 30mph it will stay in 3rd but once I hit 30mph it shifts into OD, but the RPMs are so low that it takes it awhile to get up to highway speeds. I can turn the OD off on the gear shifter but it does not deactivate the OD but the OFF light will come on. I was thinking the TPS at first but I figure that I should still be able to shut off the OD. Could it be the pack in the trans? Any ideas would be greatly appreciated.
ford5.9
ford5.9
waco/texas/us
E4OD problems
Its shifting into OD because my tac is running between 1900 to 2000 RPMs at 70mph and I'm pretty sure I have 3.54 gears.
mitsu tractor
