New member here.Was able to fix a slew of issues on this 1990 e4od truck that I just purchased.One thing that I thought might help with the thread regarding resistors for line pressure.In the post,it seems as though many were getting results..some werent.I think the confusion lies in series,and parallel.I tried 2 50 ohm in series for 100 ohms.Shifts were way too hard.Tried 1 50,still too firm.Took the 50,added 2 10 ohm in Parallel with it.Wow.Shifts are defined,no bang.And much faster also.Esp when going into od.Cant belive it is same tranny.Has to be way better for the trans.I also added a spst switch in series around resistors which when closed puts it back to factory line pressure for interstate cruising. Wellused remember..series resistance adds,parallel divides because you added more paths for the electrons to travel..reducing resistance
