The FNG
NOT a Powerstroke!
Maybe I'll be able to get an answer here, or maybe some guidance. I'm having some symptoms in my transmission. I noticed that it has been running a little warmer than usual and at times gets to be hot (205 ish) and it has been making me feel uncomfortable, especially since this is all unloaded (mostly going uphill).
I have also noticed that the shift points have changed as of recent. It likes to shift up too early and then requires me to mash on it to shift down to have any sort of power. If I don't mash on it then EGT's go up and it looks like I'm dragging a forest fire behind me. It seems that over time, things have generally gotten worse.
So here's what I did: I jumped on TDS forum and asked away. I changed my transmission fluid per instructions found here, there, and elsewhere. I also cleaned all the connections near the transmission and dabbed a bit of dielectric grease on them. I also checked my FIPL voltage.
Ground: 0.019v
Reference: 5.04v
Center wire:
Idle:1.19v
WOT: 3.85v
Seemed to be ok and voltage seemed to change smoothly with gradual throttle movement.
Well, after all of this, I went for a test drive. What a difference the new fluid made...or so I thought. The next day, I drove into work and by the time I got to the top of the hill, my trans temps were back to 200ish and I was having just as bad shift problems as before.
Something else I want to add is that my OD light is not blinking, so I shouldn't have any codes, right? Also, it shifts into 3rd from 2nd too early at times if the I use the OD button. It seems weird that if I slow down to 40-45ish on the highway that it wouldn't shift into 3rd to help me get back up to speed, it just chokes along and shortens the lifespan of people behind me with massive mounts of black smoke.
Anyway, please help me...
Ground: 0.019v
Reference: 5.04v
Center wire:
Idle:1.19v
WOT: 3.85v
