Actually
I AM the 1985 model year, the truck is 1986
M.L.S.C. is right about your controller options. To make a long story short, I highly recommend the swap if you can afford to do it properly. It will change your truck's outlook on life.
1992 is not a good year for the swap though, because the speedometer is fully electronic starting in that year. Unless your truck is 4wd, and you reuse the old transfer case, you won't have a working speedometer after the swap.
E4ODs from 1989-1991 have a cable driven speedometer and an electronic speed sensor mounted at the transmission end of the cable. 1992 and up have a VSS on the rear differential and the speedometer cable is eliminated.
