93cc7.3
needs turbo power
mine died as well but i switched over to cummins about that time so never bothered to say anything
Yes very true i kinda always felt it didnt supply enough volume once i switched pumps around it seemed to run better
Thanks for posting this info. it sounds like these pumps are just a touch under power for any turned up turbo engines. i think i would prefer to have a pump that can supply plenty of fuel and then regulate it down to a good pressure.
The bowl looks clean, maybe, there is something in the line itself lodged in an odd way where it cant clear the line. The only reason I'm not just buying another duralift, is because even when it was working as designed, it couldn't keep up with the IP at heavy throttle.
spmetimes algae can appear as a brownish l skim layer that forms over the screen. if you look at the bowl itself, it looks like theres nothing in there, but you actually have a hard restriction forming over the screen. The problem with a screen instead of a filter element is it will skin over and clog rather easily where a filter element absorbes contaminants into its element at depth over time. The advantage is, you can clean the screen quickly and be on your way., but in the case of algay, that stuff has a nasty habit of being smaller than the screen and if theres any present, you can be sure some got through and it gums things up fast.
And it may very well be possible that I have more algae in my tank than average, my tank pickup has been 1/4 tank faulty since I've had the truck, which would let water sit on the bottom of the tank.
