Dually axles + other parts
gonecrazyi
florida
I have two dually axles that need to go,
One has 4:10's and the other has 3:55's - 350 apiece obo
Front dually hubs for dana 50/60 - 150 obo
87 dana 60 kingpin axle, 3.55 gears, comes with everything needed to put into an f250. 950 obo
- Will include a matching dually (with dually adapters) or srw rearend for another 100
91 Ford 10.25, 3.55 gears - 125 - needs bearings on passenger side other
wise work fine.
Steel duallly rims - 75 a set
Chrome dually simulators - 40 a set - obo
Also have several 7.3 fuel filters and wiring harnesses.
Other parts
- Serpentine belt setup from a 94 7.3 idi
- Oil coolers - 40 obo
- oil pumps
- injection pump cores - 25 obo
- engine accessory mounting brackets
- cams
- cranks
- 7.3 turbo block (stripped and in pieces)
- Complete 7.3 minus ip - turns freely hasent run for awhile - 250 obo
- 7.3 IP gear housings with rpm sensor hole - 25 obo
- Dually bed - passenger fender cracked drivers fair - Black paint job - 200
obo
- 90 460 engine - dont know if it runs, dont have a starter or tranny - 200 obo
- 2 sets of factory overload springs with stops - 75 obo
- 91 diesel fuel sending units - worked when truck was parked (4 available) - 10 apiece obo
- cc doors - 35 apiece
- 2 7.3 wiring harnesses, 1 with a glow plug controller - 45 apiece shipped
- 1 87 - 91 hood - 25
- 87 - 91 fenders - 25 apiece - rust free could use sanding and paint
- f250 gutted single cab (just cab) with clean diesel 4x4 title - 175 obo
- vacuum pumps (untested) - 15 apiece
- F250 clutch master and slave - 30 obo (includes line) - worked when pulled
- 2 87-91 f350 crewcab 4x4 frames. - 200 apiece obo
Lots of other stuff available, just ask
If no price given make offer -
Prices are not set in stone.
skintbackfarms
AL
What part of FL are you in? How did that 7.3 motor run? (the one missing the ip)
gonecrazyi
florida
Im not sure how it ran, I got it in a trade from a buddy of mine. He said it ran before they pulled it but that it had a possible blown head gasket. I plan on trying to get it fired soon, Im kinda curious about it.
As for hubs, let me see what I have left, I may have 1 more set of hubs I just need to check.
junior20762003
VICTORIA TEXAS
- Complete 7.3 minus ip - turns freely hasent run for awhile - 250 obo whats the mileage
what about seats
are those doors auto or Manuel
tps sensors
climate control
a/c vents
what kind or wiring harness
thanks juan
gonecrazyi
florida
The seats that I have left are vinyl and are tan colored. There not to bad of shape but do have a few tears.
I have a tps sensor but the nipple for the vaccum is broken off. Im not sure if it can be replaced or removed, but you could have it for shipping if it could. It came off of the ip I sent to Mel for a rebuild.
I have everything that would be needed to put ac in a 87-91 truck. I also have ac vents as well as two trucks with complete wiring harnesses.
The doors are all manual control.
As for the motor, I was told that it had about 150k and was pulled due to a blown head gasket, previous owner decided he wanted a 460. I plan to see if I can get it to start just havent had the time. It spins freely and has compression, I just need to move it into a position where I can test it.
gonecrazyi
florida
Three,
One from an 89 7.3 - its on my truck, it runs but leaks a lot of fuel
- One from a 92 - no idea on its condition
- One from a 94 turbo motor - runs but has been sitting awhile - Id probably part with it.
junior20762003
VICTORIA TEXAS
Three,
- One from a 94 turbo motor - runs but has been sitting awhile - Id probably part with it.[/QUOTE
would you part out that turbo kit from that 94 thanks bro
junior20762003
VICTORIA TEXAS
Three,
gonecrazyi
florida
Which harnesses do you need? Same with the ac vents?
I'll try and get some pictures tomorrow for ya of the tps sensor, I wont be out to get pics of the rest of the parts till next week. Just to verify, there for the 87-91 body style.
Vents - probably 15 plus shipping
In dash harness - probably 20 plus shipping
gonecrazyi
florida
ttt
Make some offers guys,
gonna start taking stuff to scrap soon
Also have several 6.9 and 7.3 motors that I will part pieces from.
