1992 crew cab dually, zf5 and banks turbo
cpdenton
Truck needs paint.
Conway AR
Seems like it’s time to find the old truck a new home. I just do t drive it much anymore, and it sits more than it moves.
crew cab LWB dual rear wheel
223,*** miles
Original engine block
-7.3 idi
Junior moose injection pump with stock replacement injectors from conestoga
Banks sidewinder turbo kit with intercooler added and full banks exhaust
Electric fuel pump
Hydro boost brake booster
aluminum radiator
Zf5 swapped
B+W turnover ball
New 35 gallon rear fuel tank
full compliment of gauges including pyrometer, coolant temp, boost etc.
Eddie Bauer front split buckets
Kenwood CD player
it’s old, kinda ugly, but the body is solid. Zero rust, and the panels aren’t bent. I sourced replacement parts for the fender and door, as well as the bed, just never got around to painting them.
I have an extra engine block, turbo heads that have already been machined, but have sat so long the surface has begun to rust discolor some. A couple oil coolers, various extra gaskets and belts. New corner and blinker lenses for the front and many other parts that will go with it.
After it has been sitting so much, it seems to need a set of return lines and caps.
I have well over 7500 in what sits there. I’m asking 3500 OBO
Located in central Arkansas.
Wheelsrollin
