gonecrazyi
I have two dually axles that need to go,
One has 4:10's and the other has 3:55's - 350 apiece obo
Front dually hubs for dana 50/60 - 150 obo
87 dana 60 kingpin axle, 3.55 gears, comes with everything needed to put into an f250. 950 obo
- Will include a matching dually (with dually adapters) or srw rearend for another 100
91 Ford 10.25, 3.55 gears - 125 - needs bearings on passenger side other
wise work fine.
Steel duallly rims - 75 a set
Chrome dually simulators - 40 a set - obo
Also have several 7.3 fuel filters and wiring harnesses.
Other parts
- Serpentine belt setup from a 94 7.3 idi
- Oil coolers - 40 obo
- oil pumps
- injection pump cores - 25 obo
- engine accessory mounting brackets
- cams
- cranks
- 7.3 turbo block (stripped and in pieces)
- Complete 7.3 minus ip - turns freely hasent run for awhile - 250 obo
- 7.3 IP gear housings with rpm sensor hole - 25 obo
- Dually bed - passenger fender cracked drivers fair - Black paint job - 200
obo
- 90 460 engine - dont know if it runs, dont have a starter or tranny - 200 obo
- 2 sets of factory overload springs with stops - 75 obo
- 91 diesel fuel sending units - worked when truck was parked (4 available) - 10 apiece obo
- cc doors - 35 apiece
- 2 7.3 wiring harnesses, 1 with a glow plug controller - 45 apiece shipped
- 1 87 - 91 hood - 25
- 87 - 91 fenders - 25 apiece - rust free could use sanding and paint
- f250 gutted single cab (just cab) with clean diesel 4x4 title - 175 obo
- vacuum pumps (untested) - 15 apiece
- F250 clutch master and slave - 30 obo (includes line) - worked when pulled
- 2 87-91 f350 crewcab 4x4 frames. - 200 apiece obo
Lots of other stuff available, just ask
If no price given make offer -
Prices are not set in stone.
wise work fine.
Other parts
- oil pumps
- cams
- cranks
obo
