The ag balancer finally showed up!
For those of you who have heard of the difference between the bus and ag pulleys, but have not seen it, here's the photographic proof:
The one on the left is the harmonic balancer that came on the engine I have (out of a 1990 International school bus) and the one on the right is off of some sort of International tractor made in the late '80s. The listed shipping weight on the ag balancer was 22 lbs. I'd be willing to bet the balancer on the left weighs near 45 lbs. It's stupid big.
Here's a couple more shots so you can see more clearly the difference in size:
Bolting the ag balancer on will gain me 2 1/4"! That doesn't sound like a lot, but it will be part of the reason I won't have to cut up the firewall. Factory DT360 look, here I come!
Of course, modifications are not without unforeseen problems. And here's where mine begins:
If you look closely, the timing marking pin sticks out of the block at roughly the 11 o'clock position (relative to the crankshaft).
Here's the diameter of the back of the bus balancer:
And here's the diameter of the back of the ag balancer:
The ag balancer is about 1 1/4" larger in diameter.
So here's what happens when I mock it up:
Clearly, that ain't gonna work... Any ideas?
EDIT: I searched around for the Gates 44058 dimensions. I found one on Amazon that claimed 23.1 cm, a quick Google conversion told me that works out to 9.09 inches. That's longer than the one I have. I'll look some more this weekend, but I have a feeling a custom water pump is going to be necessary...
