DT360 into 1991 F350
97strokerHD
Lima Ohio
Anyone have any good links on performance upgrades for the dt360? Would love to do this swap but would want to be around 400 horse.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I have some updates. Lots of towing, a/c installation, some more burnouts. When I go to upload a picture through tapatalk, says max file size 0KB... Hmm... ***?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I think I figured it out, the forum won't allow direct uploads through Tapatalk. Test 1-2....
Sent from my SM-G920V using Tapatalk
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Ok here we go. Made a bracket to use the stock ac compressor, made a negative ground relay to kick the Volvo fan on low speed to keep me cool in traffic. With it being warm, towing, and ac on max... Temp never sees higher than 210. Perfect. Also cleaned up and finally loomed the wires.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I had to replace the injector cups. One twisted when I changed the injectors and was leaking. Took all the paint off the intake. Cleaned and touched up with a fresh sticker.
Drove it 1200 miles round trip to Charlotte for a IH show and swap meet. Hauled 6000 lbs of Detroit diesel air compressor to Virginia along the way. Trying to blend in....
Hauled an antique road grader for a friend this past weekend.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Do I use it? I'm hooked to the trailer more than I'm not. When I go somewhere without the trailer my friends ask what's broke!
New phone so that's all I have. Probably 10 more on FB I'll have to pull over one day. Hope you got a kick out of the build....BACK ONTO THE TRAVELETTE!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Much better than the turbo idi. Where I'd be in 3rd wot to keep the EGTs down, I'm part throttle 4th with room to spare. It'll climb the EGTs if you're not paying attention. Still a good haze of black smoke under load. I'd like to get a bigger turbo on it to clear that up. Works fine as is, could just use more air. Factory turbo is tiny, maxed out around 24 psi.
bob123456789
