Drilling hitch to fit new truck?
chillman88
Central NY
Ok guys I'm weighing my options here. Long story short my new truck the bumper interferes with the hitch going in far enough to pin.
The square is where the hitch "ends" on my dually.
Do I dare redrill the pin hole 7/8" farther back? Leaves approximately 1-5/8 of material in front of the pin when inserted. It's a pintle hitch for my trailer. The hitch is solid 2" square steel. Trailer weights around 2500-3000# empty and is used for hauling cars/trucks.
Alternatively I can just build a channel bumper for the new truck but I was hoping to avoid that right now.
What are your thoughts? I'm sure it will work, but I'm concerned with the added leverage put on the hitch by making it stick out further.
chillman88
Central NY
I'd think you'll be fine. We have a tri-ball hitch we use, and it had two holes in it from factory.
Yeah the second hole doesn't worry me by itself, just the fact it's back that much further.
I think I would be fine too but I'm paranoid lol
Ironman03R
Risingsun, OH (NW OH)
I'm a cheap ass too and I'd drill it, there's plenty of material infront of the new hole. Maybe weld up the old one, but if it were to break between the holes it only going to move and inch and a half.
I think you would have more chance of issues if you welded it vs leaving it alone.
Maybe I'm not visualizing exactly why it doesn't work currently, but could you just cut some off the back end to let it slide in further?
chillman88
Central NY
It's not bottoming out...
I don't have any pictures and it's raining out and I'm a wuss lol
It's a pintle hitch with lift built into it. It hits the bumper before it will go in far enough to pin it. I really don't want to cut an inch or so out of a perfectly good factory bumper.
reset2
Myersville MD USA
As long as you don't extreme load the tongue it will be fine. The things that I fret about is the 6 bolts that hold my hitch to the frame. Its always a good idea to check this from time to time.
Sent from my SM-G935V using Tapatalk
sjwelds
Central KS
Yeah I follow it.
So what, the hitch pulls maybe a 10k load?
On the hitch I mentioned the second hole was right at the end of the receiver when you were using the first hole, so all the tongue load was at the weakest point of the square bar.
Never an issue so far.
chillman88
Central NY
Yeah they should be fine, they were installed with red loctite on my dually. Definitely worth double checking on the new truck though.
Yeah I follow it.
Yeah sounds about right, could be up to around 12k but I doubt it. Thanks for the info!
The hitch is rated for 17k, I have no intention of ever loading it near that, especially on the new truck, which will pretty much only be used when the dually is down.
subway
be nice to the admin :D
York PA
would it be easier to just cut some of the back of the insert down so you can use the stock hole and not stick out any more from the receiver?
chillman88
Central NY
You're late to the party Jared :p
Merry Christmas though!
Big Bart
Tow&Slow
Newport Beach, CA
If it it uses at least 90% of the reciever depth I would drill it. But if the reciever is say 8 inches deep, and this is only going back 6 inches deep, it begs the question if you can damage or bend the reciever hole since you the hitch is not all the way in and now the hitch is pushing directly on the reciever roof and the hitch sticking out has more leverage pushing down.
You also can tow a couple of loads and jump out every 10 minutes and look to see if all is well. Then you should know. But likely you will be fine.
REM70
Staff online
