Replaced----
IAT,
PCM,
GPR,
Batteries,
EBP sensor,
Cleaned EBP tube,
Fuel Filter,
Tried different fuel,
Used a probe to check all power and grounds to PCM/relays,
removed and cleaned IPR valve + checked o-rings,
UVC harness less than 1yr old,
wiring harness is less than 1 yr old,
glow plugs are less than 1 yr old,
replaced lift pump.
Truck will still not stay started after it has been warmed up to normal operating temp. it tries and sometimes will, but it will very quickly shut off after it has started. as if something is shutting it down. at my wits end here don't know what else to do, running out of stuff to replace. any suggestions??????
IAT,
PCM,
GPR,
Batteries,
EBP sensor,
Cleaned EBP tube,
Fuel Filter,
replaced lift pump.
