the bottom set of codes came from the pcm within hours of me installing the new one...
Now that's an odd one. Normally those code will leave with the old PCM.
Here is the big question. Are the first codes still coming up? That is what I'm assuming. If they are gone you have another place to check. Code P1277 is the number 7 injector open high or low. P1278 is the number 8 injector open high or low. Time to break out the trusty ohm meter. I will need to check the trusty Powertrain Control manual to give out the ohm and pin specs. I'm getting old I can't remember that stuff.
