Does my exhaust look normal?
mntwins7
Broken 6.9
USA
New to diesels as you guys have probably seen. Anyway, I got a little video of my exhaust and it looks like there are little white puffs when I let off the gas.
https://vid.me/e/dB4F
FORDF250HDXLT
Maine & Oklahoma
that's only normal in below freezing temps.even then,that's a bit too much white on startup.
does the smoke clear up once you've run the truck for a few mins? either way,it's probably time for a set of injectors.especially if the white never clears.
ironworker40
NYC Ironworker
nj
Cranking time is a little long also. Sound isn't right either, but hard to tell with that recording.
mntwins7
Broken 6.9
USA
Ironworker could you give me a little more detail? I can get a better recording if you need
ironworker40
NYC Ironworker
nj
It seems to me idle drops low when you gas it and let off almost to the point of stalling. That along with your smoke could be injectors or ip pump. But like I said hard to tell. Next time have someone in truck and someone at the right front so they can record from there you may get better results.
mntwins7
Broken 6.9
USA
That video was taken after the car had sat for about two weeks, and it was started on a pretty much dead battery.
Today, I started the truck with a full battery, so the startup was fast and took a normal amount of time, and the idle sounded normal to me.
However, the truck still had white smoke. I drove around for a bit and still, the white smoke was there when I accelerated, even after I had gotten it warmed up.
So there's just a little more information for you guys.
Guess it looks like I'm gonna have to get some new injectors.
justinray
Contributor
Cleveland, Tx
That idle sounds low/retarded. Does what mine use to do with the idle dropping low after letting out of the throttle. I would clean the IP and injectors, and get the timing set. That should help enough to see how bad your injectors are and see how bad you need an IP.
mntwins7
Broken 6.9
USA
Not knowing any better, why would you guys say injectors? Just for my knowledge.
JU57US
