Does anyone have a good fuel sender retaining ring?
f-two-fiddy
Duluth, Mn.
I'm needing one. I scored a NOS front sender off'n eBay for my 85. But I hadda cut the old retainer with the dremel to get it off.
flareside_thun
Reviving The General Tao
Tavares, Florida
I don't have the retainer ring but if you can gimme the part number from that sender or even a link that'd be great!Good Luck
f-two-fiddy
Duluth, Mn.
I'll run out and get the number for ya
The OEM box says: E8TZ-9275-B Fuel Sender w/gskt
The Sender has a sticker on it: E8TF-9275-BA
sassyrel
iowa
or you can still get them form ford--when i worked there--parts man didnt know they were available--we had a heart to heart one day--he kept both sizes after that!!!! and the cust paid---most you pull are rusted solid--or thin as paper---
MIDNIGHT RIDER
I got two hanging in the shop that are in those Dorman/HELP packages that cost next to nothing, much less than the cost to ship one.
I will get you a part-number tomorrow.
They have the toothed ring and new O-ring.
f-two-fiddy
Duluth, Mn.
How about any tips/tricks to removing/installing these retainers?
I wish I had the proper wrench. I've always used a punch/chisel, which usually results in the predicament I'm in now.
sassyrel
iowa
sorry i didnt get right back--they werent much from ford--and the proper wrench?????????????????????? you dont need to know what ford wants for that little item!!!!!!!!!! just walk around the "toothed" part with a punch, a bit at a time--we never went looking for the wrench!!!!
MIDNIGHT RIDER
Dorman #55811
This fit the front metal tank on my 1985 perfectly.(By the way, the one the Ford parts-counter guy sold me was not even close and had to be taken back.)
The plastic rear is entirely a different animal.
To remove those rings, plenty of WD-40, some scrubbing with a wire-brush, blow away the trash with an air-hose, then more WD-40, then, like already said, walk around the perimeter with a punch, from tab to tab; I never had one break or refuse to come loose.
Devilish
Nv
I've removed many and never destroyed them. Diesel also makes a good penitrant/lubricant.
EMD_DRIVER
Say what?!?!
Beaufort, SC
None of the A/P stores around here has these things.. Where's a good place to try next? I don't need the ring.. Just the gasket..
Gary
I never thought of Dorman. I'll try their website for the P#
For future reference/search
Dorman Part # 55811
Fuel Sending Unit Retainer Kit W/Gasket
Make: Ford 2007-86
O.D.: 4-11/16" (outside locking tabs)
I.D.: 3-7/8"
https://www.dormanproducts.com/cgi-...=&start=&vfrom=&prev=&vnext=&category_list=:0
MIDNIGHT RIDER
Gary
Any Advance Auto or the like should be able to take that part-number and have one the next day.
SixFourShanks08
