DMF play
BigRedWeather
Lexington, KY
For my truck, how much rotational play (in inches or a fraction there of) is permitted? In other words, if there is more than ____ of an inch, the DMF should be replaced.
Thanks,
BigRedWeather
geonc
SPIDER BAIT
NECKVILLE North Carolina
Well...5/8" to 3/4" about the limit.......there are some pics of mine that shelled and cracked the bell hsg area---ZF's are solid casting = case and bell area are one.
clicky here for some pics.......
milner351
SE Michigan
did you have any warning before it let go?
Mine is getting noisy, it's getting close to 150k, on the original clutch as far as I know.
stop.
more diagnosis required!!!
noisy DMF's are often due to uneven firing pulses.
check your injection pump/ injectors first!!!!!!
geonc
SPIDER BAIT
stop.
Yea...I missed the fact he has a PSD! Good catch Calvin ;Sweet
Bad inj harness can cause uneven pulse firing.........
BigRedWeather
Lexington, KY
My DMF is quiet as I run down the road and at a idle. When I shut the engine off I think the noise I hear must be the DMF. It sounds like just before it completely stops turning, someone has thrown a hard stop on the engine. It sounds like those springs in the DMF are being compressed. It has sounded like this on shutdown from when I got it at 130,000 to today at 230,000.
So they only indication that I need to deal with my DMF is that there is 7/8" rotational play.
BigRedWeather
milner351
SE Michigan
BigRed describes the sound well.
My injectors are fairly new from Bean, and all my wiring is fine - she runs like a scalded ape, the only issue is some noise at idle and shut off....
geonc
SPIDER BAIT
Well...if it sounds like a washing machine on spin with an out of balance load.....then I would start planning a replacement soon!
They ARE NOT pretty when they self destruct :eek:
