dismal fuel milage even cruising on highway
69oiler
I don't feel tardy
Chardon OH
thanks Russ.
i have 2 local options for fuel. Chardon Oil sells LSD, the 500 ppm stuff. this is what i use most of the time.
GetGo sells the USLD. i only use this when i can utilize Fuel Perks, for those who dont know for each $50 you spend at Giant Eagle you get $.20 off per gallon up to 30 gallons. so i let my tank get low when i have fuel perks saved up.
regardless, i have been getting basically the same milage on both fuels. i have been toying with getting Biodiesel delivered to my house, i have a tank on a stand that i need to recondition that i would use. maybe i'll find that Bio station next time i'm in the city.
justblowin'smoke
northern illinois
if i can keep my foot out of it with the low sulfer fuel i get 18-19 empty doing 60-65. the 500 mile trip i took back in sept. i got 16 doing 75-80 and 200 miles was pullin a very well built 14,000lb trailer empty it weighed some where around 3000lbs im guessin and that was without functional cruise control
69oiler
I don't feel tardy
Chardon OH
i just performed a 2 step engine revitalization with a product by Mighty auto parts given to me by Nick (double s diesel). i was going to straight pipe the truck first but after looking at it it's not a simple task like it was on my '86 because the pipes dont line up the same way. so i decided to try this potion with my stock exhaust with muffler and convertor. i sprayed the stuff into the intake and put the other stuff in the fuel tank. we'll see what happens.
Dieselmaster
Diesel addict
Lake Havasu - Arizona
My Early 99 CC SWB LB Automatichad a 6.5" lift, 37" tires, 3.73ls.... and I consistently got 12-13 in town and 15-16 on the highway.
The only time I saw a big difference in fuel mileage was when I would run the chip on the #4 setting which was programmed for 120hp.... You couldn't touch the go pedal without a black cloud belching from the tail pipe.
Double-S-Diesel
parts seller
derry pa
Rob
awaiting results.
Ill take a looksy and see if I have a factory cat delete,
I know I have a tail pipe already welded with a straight pipe.
Nick
Rob, dumb idea, but maybe something worth a try. Find a hill on a quiet road, and stop at a marker. Put the truck in neutral and let it roll until it comes to a stop. Now do that with your IDI. Which one rolls farther? Just curious if rolling resistance, tires or some weird thing could be factored in this way. I know I've been getting 2MPG less since they switched to ULSD.
69oiler
I don't feel tardy
Chardon OH
Mel that's a very good idea. I'll try it and post the results next time i have my IDI out.
Nick i haven't done the math yet but i'm almost sown to "E" with the tank i have the additive in. trip meter says 388 or thereabouts. i do think ULSD is part of the problem.
69oiler
I don't feel tardy
Chardon OH
12.9 mpg:puke:
i fueled up and added a dose of Power Service grey bottle. it's tough to get excited about this PSD unless i can figure out how to get decent milage out of it. i hate to keep throwing all my money at this truck.
Nick i dont have the money right now for a 4" exhaust but let me know what you want for your straight pipe setup. i think my exhaust system may be the problem. if that aint it i may rethink this whole thing.
tonkadoctor
none ya bidnes
Rob, I had a local exhaust shop just chop the muffler off of mine and weld in a piece of 3-1/2" straight pipe $70.
Not sure if you'll even have a Cat on the '99 superduty, my 2000 didn't.
tbirdfiend281
Eldersburg/Sykesville, MD
the ULSD is evil, i have heard significant miledge losses from a few diesel customers, some not so much as others, but for a little bit people where definitly complaining about it, but your miledge is really low, are you 100% sure nothing is the matter with the truck?
69oiler
I don't feel tardy
Chardon OH
i'm not 100% sure of anything. my best guess is that my exhaust system is plugged up. money is tight right now or i'd get the 4" system i want. i may have a straight pipe installed on the stock system but if i go to the trouble i'd rather save up and get the 4" and be done with it. after our vacation in July i plan to bust ass and make some cash.
other than that the truck runs fine. i guess i could have it checked for codes but it's running fine and no CEL so why waste the money.
a new 4" exhaust can only help it's resale value
