Dipstick block off plug.
Josh Oldenburg
Baileyville IL
My 7.3 block has the dipstick in the front boss and a ball bearing or something blocking the rear boss. How do I remove it. Do I just stick a taper punch in and smack it with a hammer?
Sent from my Pixel 3 XL using Tapatalk
Of course I forgot this in my list on the other post. We would use RTV to seal the ball in the hole. I don't know if it's necessary, but we did it anyway.
Isaac Ristow
Somerset Wisconsin
On my old 94 idi-t i had it was loosing lots of oil. Happened to see that ball was missing. I took a bolt and covered it in ultra grey and shoved it in the hole.
renjaminfrankln
Raleigh NC
Are these only on turbos?
Mine is leaking from somewhere near the rear of the engine and I haven't found the leak yet. I don't think its the turbo drain or rear main seal.
DaveBen
Ukiah, Ca
The oil is most likely running down from the top of the engine. Look up top.
