Yup.
That will do. It definitely works as is. I turned the small section to 0.3365 and it slips in pretty tight. If you wanted a true press fit, need to go up probably another 0.003. Very light smear of rtv on the bottom and a little around the o-ring up top and she should be good to go. I put an oring on it up top. Probably wouldn't need to rtv it but I don't like leaks.
Thanks again Brian. Spot on as usual.
