I know you are always high on these aneroid valves Robert, if I do get one do you think you and the other guys from here could talk me through the adjustment or a local fuel injection shop could help if I just can't figure it out? I love to play with the truck some but the massive smoke cloud is really not me. I figure with one of these I could finish turning the pump up and maybe gain a few more ponies when enough boost is there without blacking out the town and running dangerously high EGTs.
I used to have to adjust those things all the time, it's not rocket science.I had a long conversation over teh phone with the guy at Hypermax who designed teh thing. Its setup with the same kind of adjustments as the Bosch setup, so it shouldn't be difficult to dial the thing in ( essentially it's a diaphram that pushes or pulls on a rod setting the max fuel output in relationship with the intake manifold pressure/vacuum so it's a simple matter of dialing in the amount of spring tension against the diaphram which controlls the amount of pressure needed to deliver higher amounts of fuel, in other words, you basically play with it till when standing on it, you only get a small puff that quickly dissapates as boost builds and acceleration gets steadily stronger with boost and you have your setting, if it starts falling on it's face with zero smoke at full throttle then it's requiring too much boost and needs to be backed off a bit, if still smoking like a chimny, then it needs to be set higher..
once you get it basically dialed in, then you can fool with turning the fuel up even more and playing with the anaeroid adjustment some more till you get to the point where you can no longer control the smoke output, then back teh fuel back down and you will have maximum performance, and minimal polution output i.e. volumetric efficiency at it's peak
