Diesel Bronco Dana 60 Swap
dslbroncotom
Diesel Bronco Tom
Tampa Fl
Well got the majority of the dana 60 swap done this weekend. here are the pics:
The Donor truck:
Front end removed:
Gotta love the king pins!!
Getting ready for the fun:
Old POS dana 44ttb removed:
Coil buckets removed (the longest process of the entire swap was torching and grinding all the rivets for tall the brackets!!! -cuss ):
New Spring hanger mounted:
Spring shackle hanger mounted:
Done for the night:
dslbroncotom
Diesel Bronco Tom
Tampa Fl
Today, finished mounting all the hangers, and finished installing the front end:
Got it all buttoned up, drove it 45mins on I-75 back home at 75mph with no problems and nothing but 2 fingers on the wheel.(before it was white knuckle, fighting the whole time to keep it in the lane).
Will get more pics of it completed up tomarrow
Please, please tell me those are not Boat trailer "rollers" for a body lift?cookoo They look about 4"-5" in height if I am correct and tapered which leads me to think that is exactly what they are?
I suppose if they are that makes it just that much more a swamp buggy eh?:rotflmao;Sweet
:popcorn
dslbroncotom
Diesel Bronco Tom
Tampa Fl
:popcorn
yup that is exaclty what they are. It was the cheapest way to get 6 inches of lift and i was flat broke. I did that years ago when I first got the truck, and have had no problems with it. I have the 10 boat roller halfs on energy susp. eurethan bushings, 1/2 inch grade 8 hardware instead of original 7/16, and steel triangulated reinforcements to keep it from swaying. At least I didnt use hockey pucks
Eventually, now that the SAS is complete that body lift will be coming off and a susp lift will be going on.
At least I didnt use hockey pucks ...
YOU of all people, are in NO postion to imply that those of us who have used hockey pucks, are in some way or form less technically astute!
LOL :rotflmao
Very nice job on the coil to leaf conversion though. ;Sweet
biggin92
Yeeeee Haaawwww
umatilla fl
ive always wondered how all the bronco guys suck up all the dana 60's and the 3/4 ton guys cant find any, but you answered my questions ive had for a long time , now that i know the front shacle hangers bolt in and you cut the bottom of the frame, but hay man nice job man !!
dslbroncotom
Diesel Bronco Tom
Tampa Fl
Thanks bud :cheers: Yup the front frame hangers just bolt into place, the rear 3 bolt holes line up perfectly with the 3 rivets in the front body mount, so all u gotta do is remove the rivets and thru bolt it through those 3 factory holes and it perfectly locates the hanger, then just gotta drill and bolt the front holes. also on the 3/4 and 1tons theres a large dimple in the frame where the shackle bolt goes through thats not there on a half ton so a spacer is needed between the frame rail and the shackle.
Most guys utilize a shackle reverse kit when converting to a d60 in a half ton. they box the frame horns an fabricate some front hangers outa 4x4 steel tube with a 2x4 crossmember and put the shackle on the rear of the spring. It adds like 5 inches of lift with no other modification. Eventually when Im ready to lift the truck Ill do that but for now the way I did it will suffice.
dslbroncotom
Diesel Bronco Tom
Tampa Fl
LOL :rotflmao
Whats this "YOU of all people" crap? And Exactly what "position" is it you believe Im in? :backoff;Really
Haha I wasnt implying that yall who use hockey pucks are less "technically astute" whatever that means. lol. The reason I belive the method I used is better is in the respect that the rollers are designed with a material composed specifically to withstand the elements and not dry rot and crumble, also there is a steel sleeve molded into them wich prevents them from collapsing. After 5 years they have not deteriorated in the least or given me any trouble what so ever, I have had friends who used hockey pucks and had them fail after only a few years.
Thanks! :cheers:
dslbroncotom
Diesel Bronco Tom
Tampa Fl
With the wheels on it. Only had 5 of them so gonna have to run 4 till I can get another one.
FordGuy100
Silverton, OR
Is the Dana 44HD coil over the same as a leaf sprung version?
If so I would find leaf springs and swap it into that white truck. And then sell it, and make most of your money back.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
FWIW, based on the pics of the white truck, I think it's a glider now...
MUDKICKR
NITRO WV 25143
with the way the rear dually tires stick out, i think id just run regular frt rims instead of dually frt rims. then get a set of cut out fender flares for the frt.
dslbroncotom
Diesel Bronco Tom
Tampa Fl
Na the 44 isnt a HD, just a plane old 44ttb, and the 44ttb's were never leaf sprung, I know the 44HD ttbs till 87 and then d50ttb's in the 3/4 tons were leaf sprung. But either way, that white truck isnt mine, I just bought the front end outa it from the guy. He's already made his money back plus some, got 700 from me and 600 for the alcoa's, and he only payed 1k for the thing. And hese still got the dump bed, tranny and t-case and everything else for sale too.
dslbroncotom
Diesel Bronco Tom
Tampa Fl
thought about that, but I like being able to rotate the tires, and this way I only need to carry one spare lol
